Author Topic: Brake Master Cylinder Screw Stripping  (Read 1711 times)
REdmonton
on: March 29, 2016, 12:34:59 am
I had to do some work on the front brake of my Desert Storm. When I tried to open up the Master Cylinder Top Cover screws/bolts the head on one of the screws started to strip out. Any suggestions on fixes? Anybody know the size of the bolt?
krusty
Reply #1 on: March 29, 2016, 06:07:22 am
This is a problem I have encountered on some of my previous bikes, mostly Suzukis, I now use an impact screwdriver.  Tread lightly though, just a few gentle taps with a 8 ouncer should do it. Use a really nice fitting bit.
If the screw is screwed, try knocking it round with a small pointed punch. They usually come out without too much of a fight.
Krusty
2015 RE Continental GT - Black
2016 RE Classic 500 - Lagoon Blue
Sectorsteve
Reply #2 on: March 29, 2016, 07:24:22 am
My screw heads on the master cylinder just sheared off the screw leaving  the screw to be removed from the master cylinder. Trying to rack my brains , what I did! Think I either used a really small drill bit....no that's right, there was a bit sticking up I could get pliers onto. Get the screw out and take it to yr local nuts n bolts store to get the size!
sparklow
  • Never half ass two things, whole ass one thing ...
Reply #3 on: March 29, 2016, 09:00:11 am
When you do get those screws out, use some anti-seize on the new ones!
2011 B5
2011 B5, like a Model T, comes in any color, as long as it's black.
johno
Reply #4 on: March 29, 2016, 12:07:38 pm
This problem has happened to nearly every bike I have owned, due to living on the coast in a salt air environment.
The best thing to do is carefully drill off the heads, no further than is needed to collapse the head.
lever off the brake master lid, then use mole grips (self locking pliers) to unscrew the remains of the screws.
Replace these with stainless hex socket (allan screws) machine screws, but make sure the threads have a coating of copper grease to prevent further corrosion.
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
suitcasejefferson
Reply #5 on: March 29, 2016, 05:11:04 pm
I've had this problem on nearly every Japanese bike I've ever owned. I see 3 reasons. One, the screws were overtightened on assembly. Two, they are made of VERY soft metal. Three, while they may look like Phillips screws, they are actually JIS, or Japanese Industrial Standard screws. There is a difference. I now have a set of JIS screwdrivers, but found that a fluted #2 drywall bit works well. It should work on the RE too. Put the bit in the screw and tap on it with a hammer for about 2 minutes before trying to turn it. You have to be very careful with these things. I destroyed a $150 master cylinder once, because I broke off one of the screws even with the reservoir, then cracked the reservoir trying to get it out.
Also, a bit unrelated, but if your bike spends a lot of time in the sun, I would put a piece of aluminum foil tape over the sight glass. It's not real glass but some kind of plastic, and the sun will deteriorate it fairly quickly. I've repaired several master cylinders by filling the hole where the plastic sight glass deteriorated and fell out with JB Weld, and grinding it flat.
The Old Coot
  • A car moves the body, a motorcycle moves the soul
Reply #6 on: March 30, 2016, 01:33:14 pm
I make it a habit to replace those screws with Stainless Steel Hex Head screws. The after they are in tight I drip a little bit of hot candle wax in the hex hole and let it cool. I have to replace the wax on a timely basis but it keep water from sitting in the hole and causing problem later.
2012 Kawasaki Versys
2015 Royal Enfield C5 black
2008 Bullet ES 5 Iron Barrel
Reply #7 on: March 30, 2016, 10:01:46 pm
Too late now, but I make a habit of putting the screwdriver in and giving a few nice taps with a hammer before trying to undo them on any bike.  The master cylinder screws seem to always be tight as a lug nut while also being made of very soft French cheese.  A few taps usually breaks the grip and let's me get them out without stripping. And if you have a JIS screwdriver, so much the better.  JIS screws have a dot on the head next to the cross of the slot.
heloego
  • A 2x4. My kingdom for a 2x4.
Reply #8 on: April 01, 2016, 04:14:21 pm
JIS bits or a #2 drywall bit with a few taps work great. I hedge my bet by dipping the bit in valve lapping compound.
'12 C5 Classic
REdmonton
Reply #9 on: April 01, 2016, 06:29:48 pm
I picked up an impact screwdriver. A couple of taps and it loosened right up.   :) Downside is that I couldn't free the brakes up. I had the the same problem at Singh5 did with his caliper getting stuck but I couldn't get it freed up.  :( After a trying for days I gave up and brought it into the shop.
Barnone
Reply #10 on: March 10, 2019, 07:27:26 pm
Somebody ( previous owner?) buggered up the screw head on one of the screws that hold the cap on. I tried an impact driver to no avail. Next I night try your method of drill off the head.
I am new to RE, where is a good parts source in case I have to replace the master cylinder?
Vince
2009 Suzuki TU2502X
2012 RE with Cozy sidecar
2018 Dong Fang DF250RTG
Fort Myers,FL or Robbinsville,NC
Dalmatian man
Reply #11 on: March 11, 2019, 04:38:13 am
Screw size  4mm  0.7mm pitch
33cc cyclemaster
James Cadet
James Comodore
Honda C50
Suzuki Gn250
BMW 650
Honda Hornet 600
BMW R1100RS
Royal Enfield C5 2014
Barnone
Reply #12 on: March 11, 2019, 11:03:03 am
Got some stainless steel screws at the hardware store.
The drill off the head of the buggered one and remove with vice grips worked.
Also replaced the screws on my TU259X.
Used a little anti siege.
Thanks
Vince
2009 Suzuki TU2502X
johno
Reply #13 on: March 31, 2019, 04:11:34 pm
Thanks
It's a pleasure  :)
2012 B5 Bullet
