If it would be of some use, I have available the speedo from my 2015 B5 with 306 miles that is just sitting in my garage with the cable. I put a Koso tach/speedo on last summer and am very happy with it. Send me a pm for where to send it.
!! VERY MANY THANKS for sending me the speedometer with cables !! It is of course newer version of speedo/odometer, as compared to my antique speedo ! The new one has two large screws on its back which extend out 1.5 inches
(2nd pictures below). What is the purpose of these screws ?
My OLDER speedo did not have these screws.
So my question to anyone who has similar speedo is - where do these long screws fit ? Is the bracket that holds the speedo inside the nacelle similar to mine
(3rd picture), BUT with holes for screws to pass through ? Or is it a different design of bracket ?
These long screws are at the same location where the bracket pushes the whole unit up into the roof of the nacelle
(3rd picture below). My bracket has no holes for these screws.
Anyone with a picture of inside the nacelle, behind the headlight, looking up towards the speedo that shows how these screws fit and where ?
Should these screws be cut off ?
Should I drill holes in the bracket for screws to pass through ?
