Reason for asking was to find out why dobeck efi tuner is for the 2014 model up?
They say it's not for the 2009 say it could be just connection to the injectors being I different not sur what else
Seems that I recall people talking about a wiring harness which greatly decreased the "rats nest" issues. Especially inside the casquette.
They had improved this rats nest several times sense 2009. I know my 2011 is much cleaner than some of the 2009's I've seen photos of.
The models newer than my 2011 also now have decent fuses instead of the old glass tube with metal ends that mine has.
Anyway, possibly they updated the wiring harness in 2014 and in the process, they changed the electrical connector for the fuel injector.
That would make the tuner not work with earlier model fuel injection units.
By the way, changing the fuel injector and harness at the same time would be an easy thing to control on the production build sheets and in the parts manual.
The problem with the parts manual is, the people that change it and issue it have to do their jobs or no one will know it was done until they try installing a new part with an old one.
