aboard
Author Topic: Normal muffler recommendation  (Read 2243 times)
REpozer
  • Royal Enfield Let the good times roll.
on: March 03, 2016, 05:05:56 pm
I'm looking for a RE style long muffler to replace my bazooka OEM muffler.
Recommendations please.
Of course I will cut out the hot pipe on the down pipe too.
REA # 84 ( the first time)
PerazziMx14
Reply #1 on: March 05, 2016, 12:34:34 pm
Emgo has lots of cote effective alternatives:
http://www.emgo.com/images/pdf/2016%20Muffler.pdf
I'm partial to the "cocktail/bellmouth" muffler
PerazziMx14
Reply #2 on: March 11, 2016, 04:22:25 am
Update:
Ordered a Emgo upswept cocktail shaker installed it started the motor and I found it to be painfully loud. Removed it and put it in the parts pile.
Scotty Brown
  • Scotty Brown
Reply #3 on: June 17, 2016, 12:54:24 am
A used muffler off a Harley Sportster worked just fine on my C5.  An EMGO spacer and a HD clamp and a home made bracket.  Been on now for about a year.  Not too loud and no re-mapping.  Very inexpensive remedy.
Chasfield
Reply #4 on: June 26, 2016, 06:22:47 am
I bought a large volume, cheap, Dunstall look-a-like that turned out to have very restrictive and crudely designed internal baffling - basically a length of pierced and flattened small bore tubing. It might have worked ok on a 125, but not a 500 single.
I kept the shell but junked the internal baffling:
https://forum.classicmotorworks.com/index.php/topic,19843.msg217913.html#msg217913
So you need to make sure that any after-market silencer is actually going to flow better that the OEM bazooka.
« Last Edit: June 26, 2016, 06:29:51 am by Chasfield »
2001 500 Bullet Deluxe
harshjain
Reply #5 on: August 08, 2017, 01:26:35 pm
@Scotty Brown - Can you tell me which EMGO spacer did you use ?
I did something similar, couldn't find a nice spacer, had to wrap copper sheet, does the job but looks very unprofessional :(
