Front plate
May 24, 2016, 06:58:36 am
Author Topic: the operation was a sucess and the patient lived  (Read 1977 times)
scoTTy
« on: August 12, 2007, 05:49:56 pm »
spent just about all day in the garage finishing up the 300 mile check.. ;D
twas a very HOT day :o
The throttle and clutch cables were out of adjustment and the valves are still a little loud so I am going to adjust them the way Kevin said ,tomorrow.
It was a very satisfiying experience and I learned quite a bit. 8)
I'm certain as I continue , I'll get quicker and better
Thanks to all who chipped in with their help
After supper, I'm going for my 1st ride in a couple of weeks..It's just been too hot to think,work or ride around here
scotty
scoTTy
Re: the operation was a sucess and the patient lived
« Reply #1 on: August 12, 2007, 10:12:18 pm »
about 40 miles later I find myself home.. been running on reserve for about 7 or so  miles and filled up....2.823 gallons.. gas mileage with a shade less than 400 miles on the engine....72.263549 miles a gallon.. but I have had it up to 60..  jumps out of 4th gear every once and awhile .. going to drop the shift lever a notch,,I'm really having to reach to change gears
« Last Edit: August 12, 2007, 10:14:05 pm by scotty »
gapl53
« Reply #2 on: August 13, 2007, 10:25:23 am »
I had the same problem with the shift lever. Found out that my false neutrals went away after moving the lever down a notch. Reaching for the lever with my toe was causing some sloppy shifts.
dewjantim
« Reply #3 on: August 13, 2007, 10:53:35 pm »
To help out on those sloppy shifts, try holding the shift lever in the up or down position until your clutch is released. It will stay in gear better......Dew.
