OK, really? rotate the "inlet" cam counterclockwise one notch.and i don't do anything to the exhaust cam, and this is going to make a big difference. i dont have the three position pinion, but i don't need it? OK. i'll try it. i don't have the knowledge that you experienced ones have, i don't doubt you.
the Ace cams are out of stock now anyway, and this will save a chunk of change on mid grade cams.
as for the oil line, i think it may be as simple as ordering one for a 350. but if the lower fitting does not match the case, i could cut and splice with fuel line sound good. that way if i ever wanted to verify the oil flow to the top i could leave the banjo connected , and just check it at the fuel line connection. i like that idea. if i ever get the banjos on with no leaks, i will try not to disturb them.
