Indicators and horn work. No lights. Starter motor didn't work but I kicked her over and she was running. After a while I went to start her again. Neutral light not going. Comes on when I press the elec start button. If I disconnect the rear brake light switch the fuel pump goes once. Management light stays on. Keep in mind it was all normal yesterday for a bit. I'd turn key on, decompressed, fuel pump worked mil light would turn off... Then after an hour or so she stopped. I did tap the engine into place while she was running...maybe roll over sensor...I dunno. It's weird. You don't have this with a carby!!!
Whooof !!
Dude, what did you do ! Jusssss kiddin'
OK, lets see......
"Indicators and horn work. No lights. Starter motor didn't work but I kicked her over and she was running. After a while I went to start her again. Neutral light not going. Comes on when I press the elec start button."
This to me sounds like you have a weak battery.... Likly from all the testing you have been doing. I would check the voltage and charge the battery. The neutral light may be coming on when you hit the start button, to let you know that you are not in Neutral ! And you need to shift it in to neutral. That is normal.
"If I disconnect the rear brake light switch the fuel pump goes once. Management light stays on. Keep in mind it was all normal yesterday for a bit. I'd turn key on, decompressed, fuel pump worked mil light would turn off... Then after an hour or so she stopped. I did tap the engine into place while she was running...maybe roll over sensor...I dunno. It's weird. You don't have this with a carby!!!"
Yeah, yeah Carby's don't need good batteries
Again, battery related I think. Lemme go look at the Schematic and see if there is a shared ground at the brake light switch and sensor's. The brake light switch is a ground switcher I believe......
