I have to say this is looking more and more interesting. I have to wonder if the bike is brought here what changes, if any, they will make. A Twin would be rather tasty, or i could settle for a boost to 500 cc with F.I. This bike is making me nostalgic for my old Yamaha RT1 360.
Roverman.
The specs so far:
2016 Royal Enfield Himalayan Specs –
Engine – Single cylinder, air-cooled, 4 stroke, SOHC
Displacement – 411cc
Bore x Stroke – 78mm x 86mm
Compression Ratio – 9.5:1
Maximum Power – 24.5 BHP (18.02 KW) @ 6500 rpm
Maximum Torque – 32 NM (23.6 LB FT) @ 4000 – 4500 rpm
Ignition system – TCI, multi-curve
Clutch – Wet, multi-plate
Gearbox – 5 speed constant mesh
Lubrication – Wet sump
Fueling – Carburetor with throttle position sensor
Engine start – Electric
Chassis and Suspension
Type – Half-duplex split cradle frame
Front suspension – Telescopic, 41mm fork, 200mm travel (7.874 in.)
Rear suspension – Monoshock with linkage, 180mm wheel travel (7.087 in.)
Dimensions
Wheelbase – 1465mm (57.6 in.)
Ground clearance – 220mm (8.66 in.)
Length – 2190mm (86.2 in.)
Width – 840mm (33.07 in.)
Seat height – 800mm (31.49 in.)
Height – 1360mm (flyscreen top) (53.54 in.)
Curb weight – 182 kg (401 lbs)
Fuel capacity – 15+/- 0.5 lts (3.9 gal.)
Brakes and Tires
Front tire – 90/90 – 21″
Rear tire – 120/90 – 17″
Front brakes – 300mm disc, 2-piston floating caliper
Rear brakes – 240mm disc, single piston floating caliper
Electrical system – 12 volt – DC
Battery – 12 volt, 8 AH VRLA
Headlamp – 12V H4 60 / 55 W
Taillamp – LED
Colors – Granite and Snow
You probably caught Sid Lal's comments in the video about EFI and ABS being already to go for where required.
What I want to know is how thick is the cylinder barrel wall and how thick is the cylinder liner ?
If there is enough thickness in the liner to overbore 3mm the result would be 428cc and with 10.5:1 compression that would be notable with the Mk1 butts dyno.
If there is enough material in the cylinder barrel to bore and sleeve to 86mm then it would be square 500cc lump if my math is any good.
I wonder what sort of surgery it would take to graft in a kicker ?
