Speaking of the Bullet... The GT's mapping I'm sure must be a little different.... but the concept is the same if not the actual amounts.
The Bullet dumps in a BUCKET load of fuel at start up and at idle . When you turn the key on and hit the kill switch it fires a shot of fuel into the chamber... this helps when one has a kick starter. It kind of simulates one ticking an Amal carb
. If you notice , whenever you kick the bike over, the pump comes on firing a shot of fuel. Once i'st running at idle , it idles very rich. I have seen numbers around 10-1 AFR at idle before the o2 sensor kicks in to start switching between too rich and too lean. If one does not have and o2 sensor.... like that shunt one puts in when using the PC-V, to eliminate that o2 sensor so one CAN tune... the Air fuel ratio stays at that rich mix at idle.
A stock bike and it's associated ECU and sensors , are just that .... STOCK . And the ECU is programmed as such. And EXPECTS to "see" certain voltage and resistance values , because it is stock. Once you change things, and depending on how far you go ?
For example... Cams. Cams affect the air flow though the motor, when and how right ? So. lets say you put in longer winded Cam, with more duration and more lift. This LOWERS manifold vacuum at idle... less suction at low rpm's. Less suction means less air flowing into the chamber. So you need less fuel to go along with it.. Right ? You would normally in stock form at idle see HIGH suction in that intake manifold .. especially with that throttle plate closed. And that is where the MAP sensor lives, right in that intake manifold. At idle, with some Hot rod cams in there, with the less vacuum going on , the MAP sensor MAY interpret this as the throttle plate being WIDE open !
You have less vacuum on a wide open or partially open throttle plate generally, and this is exactly what the MAP sensor measures.... MANIFOLD ABSOLUTE PRESSURE. Sooo.... ones bike MAY be dumping in more fuel " mistakenly" then it needs !
Increasing ones compression ratio will generally increase efficiency... higher pressures squeeze the air and fuel molecules tighter together for a quicker and more efficient burn.... you generally need less fuel to do the same thing.
Now, one has Cams in there effecting the air fuel requirements.... depending, but generally for long duration Cams, less fuel at idle and MUCH more as the RPMS come up. Then throw on top of that HIGHER compression ratio !
And you fuel requirements, depending on what you want to gain and at what RPM... Are going to be WAY off from stock. And if one is using a "Canned " map , that some one has created for a certain bike with exactly the same modifications... it will be "OK" Air and fuel wise. But if one deviates from having those "exactly the same modifications" .... one might not be so " OK" air and fuel wise when and where in the RPM range.
