oTTo, is that the ebc part code 90222 ?CheersPaul.
Upgraded the clutch with some new heavy duty clutch plates as the mighty fireball made the clutch slip occasionally, at least I thought so. Than I discovered that a couple of the stock clutch plates were assembled without the steel plate in between and some steel plates were stuffed at the end of the stack.
And the EBC plates still slip above 5000rpm... Going to need to throw some stronger springs in the clutch too.
I like the sound of that cause that means the engine makes so much torque.
