Otto, what did you do to get the compression increase? I haven't checked in on the GT side of the forum much lately and didn't see what you did
I'm sure Otto won't mind me replying to your question.
During the discussions about modding the GT on the Ace head thread, setting the proper squish distance was addressed. To do this, the barrel needs to be shortened by a small amount, thus raising the piston higher in the bore, so it comes closer to the head.
This raises the compression because it reduces the volume of the combustion chamber at TDC.
The piston being close to the head at TDC at the proper squish distance causes more mixture motion during combustion which helps to stave off any detonation that might accompany the compression increase.
It is a serendipitous type of mod that raises compression and staves off detonation at the same time.
