I got it running. I charged the battery. Checked and touched up the tire pressure. Got it to fire and it quit. After that it wouldn't do much. I put the charger back on. It's a DEKA AGM battery. I took a ride on my 1982 Nighthawk 450. The temp had climbed to 41 degrees with the Sun out. Tried the GT again. Started and sounded good. Got gear on and re started. Back to normal. Got some gas, 89 octane, 1.59 Gallons. It was a good ride, about ten miles. After getting back I hit the fuel tank with 1 and a half + ounces of Seafo a m. Now they're bundled under Dowcos, having burned out the water from having two feet of snow drop last week.
