My stock RE throttle grip extends about 3/4" past the end of the handlebar so the mirror tightens up against the grip. Is there a way around this?
Chris,
My stock throttle grip ends about 1/16" before the end of the bar.
What kind of bike do you have?
What kind of bar end mirrors are you putting on?
Did your bar have end-weights that needed to be removed?
When you open the throttle housing, is there a stud or screw that fits into a hole drilled inside the handle bar? Is there a hole drilled into the handle bar?
I'm trying to understand if your set-up is by design or if, for example, the throttle housing has been mounted further outward than normal. (If there is a hole in the underside of the hbar and there is a stud or screw in the housing then where is the position of the end of the throttle when they are aligned with each other...)
Matt
