My 500cc right foot shift four speed Classic is just getting to the running in nearly over stage (so now I guess it'll be running out!!!).
It pulls well and I'm letting it rev a bit more.
I think the 18t sprocket change is a viable one as it is only ridden solo and I find I'm basically in top gear at about 25-30mph indicated.
Can someone give a blow by blow account of what is involved please?
This version seems a bit 'simple'. Must be more to it.
It's not too hard, I just changed to a 19t.
]Drain primary chaincase
Remove chaincase gear and clutch (may need a clutch puller tool) When removing clutch make sure you keep order correct. Watch for clutch rod and ball bearing, they may roll out of the mainshaft gear.
Remove chaincase
You have exposed the rear sprocket gear. Remove chain.
Fold back metal folded washer (you'll see what I mean when you get here).
Using a 1 1/2 inch wrench, remove sprocket and replace with new one.
Total job time 1-2 hours
Cheers, LSM
