Wow. Went from 2016 to 2018. Most of the discussion seemed to be centered around the fuel injection. I have to wonder why you didn't go with a carb conversion instead. Mine works great. Much better than the stock EFI.
On a couple of other forums I belong to, everything is modern and EFI. The more computers the better. I figured RE enthusiasts would be more carburetor friendly. It seems strange to buy a copy of a VERY vintage bike, then stick modern computer stuff on it. The UCE Enfields only came with EFI because of the EPA. Otherwise they would still have carburetors.
Bulls eye ..!
Only concern is , now my bike has open loop EFI .
Experienced indian workshop guys have difference of opinion about the carb conversion .
Some suggest just replace the fueling part with the carburettor and you are sorted.you can have simplicity of carb and refinement of 256+ point ignition points as per load, speed and temperature ...From ECU
Some say just replacing the fueling system with carb , causes problems in the long run ..
they recommend replacing harness, stator,rotor,trigger wheel , alternator,CDi ,coil --- in short fit the entire carb bike setup ....thats expensive, labour extensive ..and will have only two ignition curves.
and i don't know the real answer ..
