Author Topic: Mjolnir ..... A 2011 B5 project  (Read 50392 times)
gremlin
Reply #135 on: May 24, 2016, 11:54:48 am
No taser on Mjolnir  (the BMW has been keeping me occupied)
but, the Triumph has been tasered for 2 years now......
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Narada
  • Riding the Madrass Missile!
Reply #136 on: May 24, 2016, 05:28:02 pm
I've been wondering about a higher output coil to stay with the recommended or even larger spark gap. That would be like a Taser.  Works good on cars.
2015 Classic Chrome/Maroon; "Bholenath", Ported head by GHG, AVL Pistons, Hitchcocks H.P. Cams, PC-V, A/T,  Kenda-761's, Koso TNT, Premium EFI Silencer.
2015 Triumph T-100 Orange/Black, TTP Stage-2 induction
2012 Triumph Scrambler / Dauntless M-72D Sidecar.
gremlin
Reply #137 on: May 24, 2016, 06:25:48 pm
just put a DC-DC booster on the supply and set it for 16 volts.
A side benefit is it'll start even if you are cranking hard and dropping the battery volts to 8 ......
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
gashousegorilla
Reply #138 on: May 24, 2016, 08:23:35 pm
  Weak anemic charging system and wiring harness.  Those yellow headlight blues at the end of a days riding.  Sputters and misfires , shitty idle and etc.   For performance....  Wider gap with higher compression and rich  AFR's, cleaner and better burn.  An improvement that can be felt.    Brilliant Gremlin.
gremlin
Reply #139 on: May 25, 2016, 01:41:17 am
quick sketch
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Narada
Reply #140 on: May 25, 2016, 04:57:09 am
Thanks Gremlin, so I just need a DC to DC booster to put on the supply side and set for 16v output.
I'm seeing them on the internet for anywhere from $1.39 to $88.20. I'll have to look into that a little later.
First the piston and head job.  Work is in progress.
gremlin
Reply #141 on: May 25, 2016, 07:55:43 pm
......First the piston and head job.  Work is in progress.
You will be pleased.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
gashousegorilla
Reply #142 on: May 25, 2016, 10:41:52 pm
   I'll get you some pictures of that install Narada.... If I can get this damn Iphone to upload !    Some reason ,it is acting up on me today ?
gashousegorilla
Reply #143 on: May 25, 2016, 11:26:43 pm
    Alright,needed an up date.   Anyway, first a shot of a BPR6ES, .035 gap with the Taser after a hundred mile gaunt today. It's about perfect, and running slightly colder then the 5...obviously.    But either would do for ME. That's with Mid-range 91 octane.  You gentleman  running the higher cylinder pressure without the cams, will likely do better with a heat range in the 7-8 area.   And I think that is what Gremlin is running now ?    Anyway... that's the heat range I used WITHOUT cams and the same Cylinder pressure.
« Last Edit: May 25, 2016, 11:30:01 pm by gashousegorilla »
gashousegorilla
Reply #144 on: May 25, 2016, 11:37:15 pm
   Some shots of the "Taser" or voltage booster with the bridge rectifier.  I put it where my roller sensor USE to be.  I eliminated that when it crapped out, and "cheated" it out with a voltage divider.
gashousegorilla
Reply #145 on: May 25, 2016, 11:47:17 pm
   And don't be like me.  Follow Gremlins clear instructions about applying copious amounts of clear silicon around that Coil  " Toroid".   I did not !  ::)   LOL !   It will vibrate an intermittently short out on the case or cover, and blow a fuse..... and make you scratch your head for a while. ::)     After my NOT following instructions, I coated that entire thing in clear silicone !  LOL !   And after at least a couple hundred miles, I'm very good.  ;)
gashousegorilla
Reply #146 on: December 21, 2016, 03:43:27 am
  Ah...beats watching TV at night.  :P ;D
gremlin
Reply #147 on: December 24, 2016, 03:40:09 am
Sweeeeeet !!!   Mjolinar is getting CAMS  !!!
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Bert Remington
Reply #148 on: April 17, 2018, 11:57:28 pm
Questions WRT Taser:
* Is 3A @ 16V (48W) booster output power sufficient?  If not, what is the recommended power?
* Would an electrolytic capacitor on the +16 booster output improve ignition function?  If so, would you suggest size.
* The function of the KBPC5010 is to protect the +16 booster output circuit from ignition coil ringing -- correct?
I am going to use this circuit on my 2016 C5.  I was planning on installing an MSD MC-2 on my BMW R1100RT.  I prefer this solution -- smaller, cheaper and probably just as good performance.  Thanks for sharing.
2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
turbosam
Reply #149 on: July 13, 2018, 12:47:33 pm
awesome thread.!!
following it to the T.
thinking of copying it on the thunderbird 500(UCE500 open loop ECU )
Any idea, whats the wattage of the stock coil, and how much boosting of voltage, the coil can comfortably take with NGK iridium plugs .
i am in to Long distance continuous riding across the temperature range.
We are living in such a world where,artificial lemon is used in a welcome drink:and Real lemon is used in the  finger bowl.!!!
