update:
The Microsquirt V2.2 board is coming along nicely in the planning stage.....
highlights >>
The board comes with 2 channels for injector control. Since we only have one injector, the second channel will be repurposed for spark.
The kit comes with a board mounted MAP sensor, this will be omitted, the RE MAP sensor will be retained.
The kit includes opto-isolator circuitry for picking up timing from the primary of a coil, this will be omitted and redesigned for use with the RE pulser coil.
a handful of other parts from the kit will be surplussed <-- always have left over parts
