If you are parking your bike outdoors in sub zero temperatures, unless you " box in" the motor, any external heat from a low wattage heater will be quickly dissipated. In days of old I used to put a fireproof blanket around the engine of my bike with one of these paraffin sump heaters under the engine. It worked fine as long as the blanket was in place.
