A heat lamp for reptiles would probably work even better.
You guys are all great. I do ride in sub 0 temps (both F and C), so how cold it gets is not a problem (I have good cold weather gear). I don't think putting a light out on my front porch under my bike would be a good idea.
Three minutes with one of these works wonders on air cooled crank start diesels, might burn your paint though.
I was looking for an oil drain pan and came across this product. Just wanted to know if any of you have encountered this before and if it works.http://www.amazon.com/Kats-1153-Handi-Heat-Magnetic-Heater/dp/B000BOABS6/ref=pd_bxgy_263_2?ie=UTF8&refRID=155Y0EDSG22BMDC1ZJ3W
