I like closed loop systems. Perhaps due to those Navy fire control engineers forming my brain at a tender age. But I also learned, sometimes painfully, доверять, но проверить. Your sensors are going to lie and your actuators are going to ignore you. And both are expensive so choose and use them for maximum ROI.
Based on its size, pin count and contemporaries I expect the RE Keihin ECU is a sophisticated p, αlpha, N system with dual AFR mapping table and long-term trim capabilities. But does RE fully use those capabilities like Triumph apparently does? Certainly there seems to be no equivalent to Triumph's TuneECU feature although this warrants further investigation.
Let's explore this using fuel injection pressure correction possibilities. The fuel pump is in the sealed gas tank, which is common for fuel injection as the higher pressures typically require a fuel-cooled pump. The in-tank piping includes a nominal 40psi pressure regulator and the tank itself is vented through a 3-way valve whose closed-open activation pressure seems to be 1-2psi. The ECU controls the closed-open fuel injector valve with a single, variable-width pulse. The fuel injector is working into the varying intake manifold vacuum.
Is this tank-to-intake variance significant? In my experience, external return-to-tank pressure regulators include a hose to the throttle body to provide a consistent injector-to-intake pressure differential. I'm not sure how this differential is maintained, or even if it is, for non-return-to-tank systems like the RE. But my research leads me to believe it is significant and that modern systems provide some means to adjust for the varying injector-to-intake pressure differential.
If the RE ECU does provide this adjustment, then two methods are available: MAP feed-forward and HEGO feed-back. The MAP method is a simple and direct atmospheric-to-intake measurement but it doesn't compensate for tank venting events of 1-2psi. Since the bottom port of 3-way valve is connected to the TB Purge port, perhaps the intake vacuum is reducing the events to fractions of psi so no compensation is needed. The HEGO method is more complex (what is the cause of the AFR change?) but in all cases enables correction for all causes. For both MAP and HEGO the correction is increased or decreased fuel injector pulse width.
Let's step sideways for a moment and examine the AF-XIED and RB Easy AFR modifiers.
My specific AF-XIED, which I borrowed from my BMW, is configured to the R1100's Motronic αlpha, N system (more modern AF-XIED configurations are available). While having two cylinders, the BMW fuels and sparks like the RE: every rotation which means alternating "dead" and "live" fuel and spark events for each cylinder. It has a potentiometer to vary the AFR.
An example RB Easy for the KTM 390 (
https://rapidbike.us/products/rb-easy-ktm-390-duke-rc-2012-2017) which likely to be a modern p, αlpha, N system. The Easy has two controls, a multi-position switch for a specific make/model configuration and a potentiometer to vary the AFR.
Since both are in the post-combustion feedback loop, I don't think the difference between the αlpha, N AF-XIED and the p, αlpha, N RB Easy will be significant. But then again I could be wrong.
Returning to the main path, what does this mean for choosing AF-XIED or RB Easy vs PCV?
If RE's programming of the Keihin ECU is as crude as it appears on the surface, then the open-loop PCV is the better, albeit more complicated, choice.
If RE's programming of the Keihin ECU is more capable including long-term trim, TPS reset protocol, tank-to-intake differential compensation, etc then the closed-loop AF-XIED or RB Easy are the better and simpler choice.
Which almost answers the initiating question.
So how crude/capable is the RE programming of the Keihin ECU? I'll search the Triumph forums for more clues.
And returning to my infuriating EVP experience, let's just say I'm not going to be in a hurry to mount the canister behind the engine.
That's all for now. What are your thoughts?
