I'm an analog and tube guy.
I have a high-end fully manual Teres 320 turntable with with a heavy platter and an Origin Live Silver tonearm(modded), a Shelter 501 Mk2 moving coil cartridge, and a lot of vinyl.
Mitch Cotter moving coil cartridge pre-preamp.
Magus "C" modified and re-capped tube preamp with tube phone preamp section and remote power supply.
Custom one-of-a-kind David Berning low power tube amp, Output Transformerless ZOTL Single-Ended Triode type with Emission Labs Type 45 output tubes and 6NS7 input stage tubes, choke loaded, and operates off 12vdc to eliminate powerline grunge and fluctuations. 2 watts per channel of very clean Class A SET tube power. He built this for me, based on his SET ZOTL circuit for the David Berning Seigfried amp, but changed it to the very low power 45 output tubes and choke loading and 12vdc power. It is the only one of its kind.
Speakers are Lowther single driver systems in my own design of Voigt Pipe type cabinets with modifications.
