Maggie's new look for fall.
April 29, 2016, 08:59:06 am
Author Topic: Bullet 500ccs 20002 European Electronic Ignition- TIMING  (Read 3788 times)
maxy123
« on: August 21, 2008, 09:42:12 am »
The above machine backfires on startup.I adjusted
the 'electronic points' within the range of the
elongated screws and no improvement. In fact the timing
seems to be slowly getting worse even though the only adjustment
 carried out was the above. What is the correct procedure please?
I use the kickstart to start as the backfire seems to have
damaged the starter clutch.
Is there a procedure for starting using the kickstart  to eliminate
or reduce the  backfiring
The standard start method as with normal points does not seem to apply
Thank you for your interest and help
soulcatcher3
Re: Bullet 500ccs 20002 European Electronic Ignition- TIMING
« Reply #1 on: September 01, 2008, 08:42:31 pm »
Mate...it's a shame no-one has replied to you yet...perhaps your Q; would be better in the Classic Bullet section.
 Anyways...I have electronic ignition timing on my bike, and to adjust the timing without having contact points to visually aid the situation was a bit of trial and error- it takes some time perhaps, and a few adjustments back and forth with the timing plate, ( and there is a trick to doing that!) before you'll get it just right.
 Try like this...if your Bullet is backfiring at start up, check your manual to see if that means that your timing is either too far retarded or advanced. ( I'm not sure and don't have the manual in front of me.) Then, perhaps you should slightly adjust the timing plate ( advance or retard ) to either the left or right, before setting the carb. An adjustment should be slight, not swinging the plate all the way to the opposite side!
 To make a fine and very small adjustment, loosen off the 2 bolts that hold the timing plate in place, not too loose, and one at a time; then hand pinch them back so they are holding the plate without it moving easily. Then, with  a flat screwdriver sitting in the notch,tap it slightly making the plate move SLIGHTLY to advance or retard the timing.
 (If this first setting doesn't work out later, then you will just start again from step #1)
  After this small and slight adjustment, don't tighten up those 2 bolts, just make sure they are hand pinched....and leave the cover off.
 Then, you really need to have the carberettor adjusted as best as you can get it. These details of setting the carb should also be in your manual, or can be got off the Royal Enfield Bullet manual available on the internet.
 Once this is done, and hopefully you can get it to run at least without cutting out from backfiring, you can then fine adjust the timing again by tapping the plate a little more to the left or/and right with the screwdriver (I use a rubber handled screwdriver and a small hammer to tap it with) - and this can be done while the engine is ticking over, so you may need to warm up the engine for a couple of minutes first, and if you have to ( until the timing is just right ), notch up your idling revs a little by turning the idling screw on the carb as much as necessary to stop it from cutting out ). The point of adjusting the timing plate while ticking over the engine, is to find the sweetest sound of your engine where it's purring,not coughing! If/when it does that, she's set pretty good.
 Now, having the electronic ignition timing, and without the contact points, it is my understanding that the ammeter will not work quite as it would if you had the points; (at least it doesn't work on mine) so basically, before kick-starting the bike over, you need to get the TDC position by basically LISTENING to the engine; while slowly cranking it over at the same time. With the decrompressor switch engaged, slowly crank the motor over until you hear a swoosh sound, and just a very slight crank after that it makes another quieter hiss. The engine is now at TDC ( or somewhere close to it!) You can also check this ( and would be a good idea to get used to this method, so you'll know better where to find exact TDC by sound ) by taking off the tappet rod adjustment cover on the right side of the engine, and when you think you are at TDC, check to see that the tappet rods are set correctly. If they are not in the correct position,you are also not at TDC; then observe them while you hand crank the engine over again,( and listening ) with the decrompressor switch engaged. The front rod (exhaust) will rise up, then be the first to come back down....and just a little way behind it, the rear rod ( inlet ) will follow. A position JUST AFTER the rear rod hits the bottom is TDC, and when both rods should be able to be thumb twisted at cold.
 I find to start my engine at cold, I don't use the choke,( but it is pretty warm at this time of year). When I kick over the engine to start, I hold the throttle steady at just a pinch on from off...just letting a small amount of gasoline into the carb, otherwise mine can kick back...but if i adhere to this starting method, I have no problems at all.
 As for any problems with your electronic starter...i have no ideas, as my bike is only kickstarting.
 ps...Don't forget to TIGHTEN up the plate ( with the 2 screws ) before putting the plate cover back on the bike.
 pps...sorry my explanation was so long-winded, but it's really just a few trials and tribulations to get it all set right.
 Hope this helps...I'm no expert, but do all my work my-self so far, and this worked for me...since I set my timing like that,I've ridden nearly 1000 miles running in, and the timing seems to be set perfectly, as she runs like a dream.
 i also had initial problems with back-firing and cutting out, no tick-over etc, and after firstly adjusting every thing, i found that the problem was actually crap in the carb....so once that was cleaned, I needed to set the timing properly again....but I learnt a lot, so all is good.
 GGOD LUCK.....Phil
t120rbullet
« Reply #2 on: September 01, 2008, 09:32:07 pm »
Don't know what kind of electronic ignition you have but the Boyer unit will advance the timing when the battery is low. Having a battery that is 100% is critical to them.
soulcatcher3
« Reply #3 on: September 02, 2008, 09:56:13 am »
That's good info...Maxy, you should check to see if you have a Boyer unit, and check your battery...Mine is not a Boyer, just some other brand out of India that was fitted to the Bike when I purchased it in Delhi.
 Phil
« Reply #4 on: September 12, 2008, 05:04:41 pm »
Can I interest anyone in a set of points? ;D
bob bezin
  • I ride therefore I am.
« Reply #5 on: September 13, 2008, 07:52:54 am »
i thought the 20002 re would be running on a byrilliam sphere and neither points or electronic ignition.
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
geoffbaker
« Reply #6 on: September 24, 2008, 06:08:24 pm »
If I have learned anything about RE's it is that they don't change much. I fully expect that in 20,002 you will be able to buy a 500 kickstart model, with points.
Of course, by then gas will cost $200,000 a liter (yes, the US will have gone metric, way back in 19,999), and we will be speaking Chinese.
