Author Topic: How delicate is the stock speedo?  (Read 1787 times)
dginfw
on: November 19, 2015, 08:37:37 pm
While limited range of motion in my arm is still keeping me from riding, I got out in the garage to do some light duty tinkering...
 months ago while my engine was apart  I replaced the warning lights with LED bulbs (definitely a good upgrade) but on the initial run I noticed the speedo wasn't working. I figured one of the cable ends wasn't properly done so when I checked that today I found that the end at the speedo was indeed turning with the front wheel, so the sending unit seems to be working. I redid the upper connection and spun the wheel, but the needle didn't wiggle or move even a little. Then I connected a drill to the speedo -yes I checked the direction- and spun it faster and it still didn't move.
Do they die at random, or did I accidentally kill it when I pulled it for bulb replacement?
                    '12 C5 military -sold
                    '14 Continental GT-  sold
Reply #1 on: November 20, 2015, 01:30:41 am
 Re: How delicate is the stock speedo?
 They are fairly robust and old school mechanical, the parts inside are simple but don't accidentally step on them.
 :P
« Last Edit: November 20, 2015, 01:52:15 am by Ice »
Reply #2 on: November 20, 2015, 02:07:59 am
With the old mechanical speedometers, sometimes the drive cable isn't long enough to enter the square drive in it.
I don't know how you connected the drill to the speedometer but if you used a square drive and the input was actually turning without the speedometer needle moving it does sound like you've got a problem.
Many cities have speedometer shops and if you can find one, they should be able to get the thing working again.
strat71
Reply #3 on: November 20, 2015, 04:36:31 pm
Mine suffer from the same symptoms...
it worked... had to disconnect it to remove the front wheel...
and it don't work no more.. i checked that the cable is turning up to the front... but the speedo needle don't move...
i removed the speedo and tried to turn the square hole... and it feels very stifff!!! and the needle is hardly moving...
it's only 21km so i decided to change it since the stock one doesn't have a neutral light... and i could use a neutral warning.. even if i get used to know where i am on the gear box...  ;)
Ben
Ben
dginfw
Reply #4 on: November 20, 2015, 08:38:07 pm
Mine is just the opposite. the square hole turns very easy...no movement on the needle at all
