While limited range of motion in my arm is still keeping me from riding, I got out in the garage to do some light duty tinkering...
months ago while my engine was apart I replaced the warning lights with LED bulbs (definitely a good upgrade) but on the initial run I noticed the speedo wasn't working. I figured one of the cable ends wasn't properly done so when I checked that today I found that the end at the speedo was indeed turning with the front wheel, so the sending unit seems to be working. I redid the upper connection and spun the wheel, but the needle didn't wiggle or move even a little. Then I connected a drill to the speedo -yes I checked the direction- and spun it faster and it still didn't move.
Do they die at random, or did I accidentally kill it when I pulled it for bulb replacement?
