If you're using an aftermarket air filter and not the factory airbox, you're adding a lot of extra weight to the end of the intake line and stressing that intake hose. I'd recommend purchasing one of Ace's air canisters. One benefit is the support bracket at the bottom of the canister, which keeps the carb supported well and relieves that extra stress on the intake hose.
