Yes, for the 3rd harmonic frequency, it could be anywhere from 1" - 3"(or even more) longer, depending on what rpm you want your target to be.
We have typically used 12" length for the Fireball at 6000 rpm.
Length is measured from the back of the intake valve to the bellmouth. I can't remember the length of the UCE intake port.
Also, the calculated length is the center of the affected rpm range, so it has results above and below the actual center, to some degree. And if you want a "hard and narrow" tuning, you can use a straight walled stack with a small flare. If you want a "softer and wider" tuning, you can use a widening wall stack with a big flare. Keep the effective width of the bellmouth less than 3.5" if possible, for best harmonic effects based on lower cutoff frequency affecting the wave reflection.
Some experiments with the length can yield benefits because the calculation only gets you in the ballpark.
