The calc. corresponds exactly with the Helmholtz resonator / Single cavity resonator.
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/cavity.htmlIncreasing the diameter of the snorkel, it needs to be even longer. Here some examples.
Exampel 1:
Airbox volume V = 0,005 m^3 305,12 cu. inch
Snorkel diameter d = 0,1 m 3,94 inch
Snorkel area A = 0,007853982 m^2 12,17 sq. inch
Snorkel length L = 2,2 m 86,61 inch
Exapel 2:
Snorkel diameter d = 0,08 m 3,15 inch
Snorkel area A = 0,005026548 m^2 7,79 sq. inch
Snorkel length L = 1,4 m 55,12 inch
This all would not seem such a problem if it was a 2 cylinder engine, running some 10000 rpm. In this case the result would be (realistic):
Snorkel length L = 0,1 m 3,94 inch
So after this, it doesn't seem to be too hopefull for our bike to get a realistic solution for a tuned airbox done. Unless a multiple of the frequency could be used?
