Author Topic: Comic Section  (Read 23250 times)
  • Global Moderator
Reply #30 on: November 29, 2015, 12:39:37 am
Totally an American thing
www.cyclesidecar.com
Reply #31 on: November 29, 2015, 04:24:59 am
chuychacon
  • TEAM BANZAI 88
Reply #32 on: November 29, 2015, 03:56:13 pm
we are all winners :o :'(
just show up! :-X
Moto Guzzi Lemans 1980
Kawasaki 750 Twin Cafe 1982
Honda XL 350 older brothers age 18-20
Honda Dream 50cc hand me down age10-14
Otto_Ing
Reply #33 on: November 29, 2015, 08:27:41 pm
School?    :-X :'(
Uncle Billy
  • Still knee dragging (now and then) after 60 years.
Reply #34 on: December 05, 2015, 02:31:24 pm
2019 Royal Enfield 650 GT
2014 Royal Enfield 535 GT
1984 HONDA VF750 INTERCEPTOR
1975 Yamaha DT 100
1973 Yamaha RD 250 made into a cafe racer in 1975
1973 Yamaha TY 175 Trialer
1966 Yamaha DT 125 Enduro   X2
Reply #35 on: December 05, 2015, 07:03:19 pm
Uncle Billy - I haven't laughed that hard in a long time - thanks for that!
Otto_Ing
Reply #36 on: January 04, 2016, 03:59:45 pm
https://youtu.be/V8COCPyB-go
Classic TT .... looks like a jap bike.  ;D
« Last Edit: January 04, 2016, 06:34:59 pm by Otto »
malky
  • Team Rough Inferior.
Reply #37 on: January 04, 2016, 06:18:34 pm
I was Molly Sugdens bridesmaid.
Spontaneity is the cure for best laid plans.
‘S Rioghal Mo Dhream
Uncle Billy
Reply #38 on: January 05, 2016, 11:37:41 am
I hope this isn't too offensive; if it is the mods will delete it.
1975 Yamaha DT 100
Otto_Ing
Reply #39 on: January 05, 2016, 11:43:07 am
 ;D ... very funny. Not to worry, I think this is the last place where the feminist and gender extremists are about to look.
« Last Edit: January 05, 2016, 11:59:23 am by Otto »
Otto_Ing
Reply #40 on: January 05, 2016, 08:56:49 pm
very funny video...
https://www.youtube.com/watch?v=NdKqe0LdWwc
Harley Davidson Chopper vs. Sport Bike Race
Otto_Ing
Reply #41 on: January 17, 2016, 09:36:13 pm
;D
« Last Edit: January 17, 2016, 10:11:04 pm by oTTo »
SteveThackery
  • Inveterate tinkerer
  • "If it ain't broke, keep fixing it until it is."
Reply #42 on: January 18, 2016, 10:15:03 am
I wish I could find out who wrote this, as I'd love to acknowledge their authorship.  Anyway, I think it's great.........
Synthetic Oil
Beware of synthetic oil, it can do terrible things to you and your
beloved motorcycle. It will not only leak out of your engine faster
than you can put it in, but it will also cause your oil filter to
clog and implode, dumping debris and dirt into your lubrication
system. It also will make every part of your bike permanently
slippery because of its linear molecular chain dispersion action.
Then it will leak onto your kickstand causing it to retract
automatically, dropping your bike on the ground!
But that's not all...
Synthetic oil will round off your gears and spin your bearings. It
will also splatter onto your seat causing your girlfriend to fall
off in the apex of a turn and she'll never ride with you again.
Synthetic oil coats your sight window and your timing window
with a  whitish pro-emulsification additive that is both non-
removable and highly corrosive. Synthetic oil will completely
leak onto the ground overnight  and your dog will drink it and die.
Synthetic oil will wear out your tires and make your battery leak.
 It will give you the desperate need to urinate after you put your
full leathers on and then jam your zippers shut. It will contaminate
your gasoline causing your bike to stall on railroad tracks and
accelerate uncontrollably near police cars. It will make it rain
during rallies  and on weekends.
It will lubricate your timing belts causing them to  jump teeth and
break your valves to bits. Synthetic oil chemically  weakens
desmodromic valves and causes the clearances to change
every  six miles. Then it melts the black soles of your riding
boots right  before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of
your handlebar grips to slip off at the same time so you smash
your  windscreen with the bridge of your nose. It also causes your
swingarm to crack, your studs to break, and your rotors to warp,
and then it  voids your warranty by changing your odometer
reading to 55,555. It  also dries out your wetclutch and wets your
dryclutch. It makes your  clutch slave cylinder seal fail in the
heaviest traffic on the  hottest day of the year while putting an
angry wasp in your helmet for good  measure.
Synthetic oil hides your 13mm socket and puts superglue on your
earplugs. Synthetic oil will scratch your faceshield and make your
gloves shrink two sizes right before trackday. Synthetic oil stole
your neutral and sold it to the Chinese for $1.25. Synthetic oil
will make you grow a tail. Synthetic oil will write long crazy
e-mails to your Internet friends and then sign your name at the
bottom!
Meteor 350
Previous:
'14 B5
'06 ElectraX (Good bike, had no trouble at all)
'02 500ES (Fully "Hitchcocked" - 535, cams, piston, etc - and still a piece of junk)
...plus loads of other bikes: German, British, Japanese, Italian, East European.
SteveThackery
Reply #43 on: January 18, 2016, 10:20:56 am
Anyone who's owned a Brit bike will have fond memories of Lucas products.....
The three-position Lucas switch--DIM, FLICKER and OFF. The other three switch settings--SMOKE, SMOLDER and IGNITE.
"I've had a Lucas pacemaker for years and have never experienced any prob..."
It's not true that Lucas, in 1947, tried to get Parliament to repeal Ohm's Law. They withdrew their efforts when they met too much resistance.
Back in the '70s Lucas decided to diversify its product line and began manufacturing vacuum cleaners. It was the only product they offered which didn't suck.
Meteor 350
Previous:
'14 B5
SteveThackery
Reply #44 on: January 18, 2016, 10:30:19 am
Manly Men's Tool Descriptions
 DRILL PRESS:
 A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted race car part you were drying.
 WIRE WHEEL;
 Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
 ELECTRIC HAND DRILL:
 Normally used for spinning pop rivets in their holes until you die of old age.
 PLIERS:
 Used to round off bolt heads.
 HACKSAW:
 One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
 VISE-GRIPS:
 Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
 OXYACETYLENE TORCH:
 Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
 WHITWORTH SOCKETS:
 Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
 HYDRAULIC FLOOR JACK:
 Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
 EIGHT-FOOT LONG DOUGLAS FIR 2X4:
 Used for levering an automobile upward off a hydraulic jack handle.
 TWEEZERS:
 A tool for removing wood splinters.
 PHONE:
 Tool for calling your neighbors to see if he has another hydraulic floor jack.
 SNAP-ON GASKET SCRAPER:
 Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog**** off your boot.
 E-Z OUT BOLT AND STUD EXTRACTOR:
 A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
 TWO-TON ENGINE HOIST:
 A tool for testing the tensile strength on everything you forgot to disconnect.
 CRAFTSMAN 1/2 x 16 INCH SCREWDRIVER:
 A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
 AVIATION METAL SNIPS:
 See hacksaw.
 TROUBLE LIGHT:
 The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
 PHILLIPS SCREWDRIVER:
 Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
 AIR COMPRESSOR:
 A machine that takes energy produced in a Nuclear power plant far away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads.
 PRY BAR:
 A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50¢ part. HOSE CUTTER: A tool used to cut hoses too short.
 HAMMER:
 Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
 MECHANIC'S KNIFE:
  Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
 DAMMIT TOOL:
 Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
 EXPLETIVE:
 A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Meteor 350
Previous:
'14 B5
