Ice - not sure what's going on with the pics... they're showing up fine on my screen. Looks like Jerry can see 'em, too.
Jerry - by gum, you're right! I've taken a closer look, here's a close-up of cracking between the "blocks":
If I understand date codes, this tire was made in early August of 2012:
The tire tread is almost gone anyway, scalloping aside, so I'm not too upset about it. The only riding I have left is a final pre-storage gas-up anyway.
18 psi is the OEM spec - some guys here use more, but many stick with it on the road with no issues. I figured RE specifies it for a reason. Handling and performance has been exemplary at that pressure, and I think 7000 miles on a good sticky front tire is just fine (I get 1/2 that on the rear K70). I can't feel any steering or handling problems, but taking into account all the above, I consider that tire done.
