It could be anything from someone putting a lot of oil in the cylinder to preserve it during storage to someone not putting anything into the cylinder and it has now rusted the rings.
It also could be that someone put oil into the fuel tank to keep it from rusting and this oil has mixed with the fuel and is now causing the smoking.
Also, because we don't know the color of the smoke, the above guesses assumes it is due to excess oil.
If the smoke is black rather than blue/gray, it could be due to the float in the carburetor sinking, or more likely stuck in the "open" position and now an excess of fuel is being dumped into the carb.
If the smoke is white and it seems to evaporate into the air, it could be water vapor from water that was trapped in the silencer. As it boils off, it turns to steam. (This often happens in cold weather but almost never when the air temperature is warm.)
