A few days ago, it rained and I didn't think anything of it. I've ridden in the rain before without issue. This time though, was different. I headed home while it was raining and noticed that my turn signals and horn stopped working. I pulled over, looked at the fuse and sure enough, it was blown. I replace the fuse, then try to get home again. About 20 minutes later and not more than two miles from home, she died completely. I pulled over again and looked at the fuses. This time, I had blown the main fuse. I replace it, then get back on and head home again. Before I make it 30 feet, the signal and horn fuse blew again. I got home, parked her in her normal spot, then went inside. It hasn't rained since that day, but I have blown the signal and horn fuse at least once a day. I thought the issue might be with my horn, so I disconnected it this morning, verified that the fuse was good and rode to work. About 20 minutes into my ride, I noticed that my turn signals weren't working again. Something is overloading the signal and horn connection. Do any of you have any ideas about the cause of this problem?
