I hit 600 miles so I changed the oil and filter again. The suction filter mesh was totally clean, and very little fur was on the drain plug magnets.
I filled her up with fresh Motorex 15W50 semi synthetic (Cycle Gear was out of Motul) and I'll run that until I have 1000 miles.
After that, I'm thinking Mobil 1 V Twin 20W50 and a filter replacement at 2,000 mile intervals. It's good oil, less expensive than the "boutique" oils I've been using, and readily available nearly everywhere.
