I measured how much oil was drained from by GT: About 5 5/8 pints measured using a graduated pitcher used to mix 2-stroke fuel. That converts to about 2.6 quarts. Silly me, I thought the 2 quarts of lube I got from nField in their oil change kit was enough since I found the kit in the "Continental GT 2014 > Oils > Filters & Chemicals > Complete Oil Change Kit" page of their on-line catalog and I didn't read the fine print there. The fine print:
"**The G5 kit is for G5 models fitted with 2-hole oil filter cover. If your G5 has a 3 hole oil filter cover, order the C5,B5,GT kit (Z92102)**
** Newer models will have a second oil drain plug; in some instances this style of case will require more than 2 quarts of oil. We have added a 3 quart option for customers that may need more oil.**
It's also in the owner's manual: 2.75 quarts (dry fill) which I also didn't look up before hand. My bad, all round. Sorry!
For those doing an oil change for the first time, here's a helpful narration published in "Motorcycle Classics" magazine, which is on my short list of great magazines:
http://www.motorcycleclassics.com/mc-how-to/2015-royal-enfield-continental-gt-maintenance.aspx
