Author Topic: How Many Chain Links?  (Read 6866 times)
firecaptp7
on: October 08, 2015, 02:02:05 am
« Last Edit: March 05, 2016, 05:23:44 pm by firecaptp7 »
Reply #1 on: October 08, 2015, 02:14:10 am
Yes.  The #530 is the right size chain.
As for the number of links, I'm pretty sure your C5 with the 18" rear wheel uses the 102 link chain.
I know my G5 with the 19" rear wheel has a drive sprocket that is one tooth smaller than the C5 sprocket and it uses a 101 link chain.
That 101 link chain is a bastard size as far as the chain makers are concerned and it needs to have a "half link" installed to get the odd, 101 number of links.
Just to be on the safe side though, count the number of links in your chain.  It goes pretty quickly if you put the motorcycle on its center stand so the rear wheel can rotate and then start counting with the master link being #1. :)
GSS
Reply #2 on: October 08, 2015, 02:22:34 am
As always Br. Arizoni is right.  It is 530 o-ring with 102 links.
GSS
2019 Himalayan Snow
Previous REs:
Reply #3 on: October 08, 2015, 02:27:19 am
De greasing and painting the master link before installation makes it easy to spot.
Mr.Mazza
  • Upside down thumping
Reply #4 on: October 08, 2015, 03:01:44 am
Most chains come 120 or 140 links, just lay next to old one, mark length and break chain :)
wildbill
Reply #5 on: October 08, 2015, 04:31:01 am
102 x 530 is spot on. plus I suppose you have the 2" of slack chain measured from the bottom while your bike is on the centre stand.
as for that factory "o" ring chain it can be a hit and miss affair. I had one that bad on a previous c5 that it only lasted 300 miles from new and the links froze in several sections. once off the bike you could hold it vertical and actually make a nice zigzag pattern  ;D.
anyway its worth the upgrade alone to jump to a better quality chain and they appear to run quieter plus it might get rid of the noise you are hearing
ROVERMAN
Reply #6 on: October 08, 2015, 08:06:48 pm
As we have discussed in another thread,me too. The vibes come in like a shuddering dog! Right through the footpegs.
Roverman.
tenacres650
Reply #7 on: October 08, 2015, 09:02:57 pm
Thanks for the guidance. Hope to pick up a 530 X 102 o-ring chain today. For clarification .... My vibration is not a noise but something felt throughout the motorcycle ... primarily at the footpegs.
probably wont come in 102 normal is 120 I think. Count yours before you remove it, then cut yours the same. Don't remove the old chain until you're ready to install the new one, remove the old master link, join your chain to the old chain and let it thread the new chain on for you.
phoenixt
  • "All that is rare is for the rare" Nietzsche
Reply #8 on: October 08, 2015, 09:34:37 pm
... Don't remove the old chain until you're ready to install the new one, remove the old master link, join your chain to the old chain and let it thread the new chain on for you.
I just used this method on my GT. Worked like a charm.
Steve
“Those who have a 'why' to live, can bear with almost any 'how'.”
― Viktor E. Frankl
The Old Coot
  • A car moves the body, a motorcycle moves the soul
Reply #9 on: October 08, 2015, 10:09:56 pm
+1 on breaking the chain. I buy the longest 520 "X" ring chain I can when I see them on sale as both my Kawasaki use that size BUT need a different number of links, I just cut it to fit whatever bike I need a chain on at the time.
2012 Kawasaki Versys
2015 Royal Enfield C5 black
2008 Bullet ES 5 Iron Barrel
johno
  • 2012 B5 on the original Portland Dorset UK
Reply #10 on: October 09, 2015, 09:26:54 pm
No one has mentioned it, but does an o ring chain fit on a C5?
I had to go with a heavy duty standard 530 102 link chain on my B5 even with a larger drive sprocket the clearance is small between chain and crank case.
2012 B5 Bullet
 K&N, sport muffler, 18tooth fr sprocket, Avon style fairing, 1958 pattern British army haversacks. Mitas tyres DiD chain. Carberry plate.
The Old Coot
Reply #11 on: October 09, 2015, 09:32:57 pm
I'm looking at a 520 front sprocket from Hitchcocks and the rear drum and replaceable sprocket from our host. I'll have to buy a 520 rear sprocket and then machine it fit but I have the chains and I can't see a RE ever wearing one out from overpowering it.
tenacres650
Reply #12 on: October 09, 2015, 10:26:18 pm
my C5 '13 came with an O ring chain from new.
wildbill
Reply #13 on: October 09, 2015, 10:47:20 pm
well as factory standard equipment you do get an "0" ring chain on a C5 but what you really require is a good "0"  ring chain  ;D and that would be  8)...lol
The Old Coot
Reply #14 on: October 09, 2015, 11:04:31 pm
Now Bill you're NOT saying the factory chain is less than the best are you?  ::)
