Its either the stock piston or a high comp, but its running at 135psi cold compression tested. I would have to look, but this bike does run very well, I am not inclined to think there is a problem. There is no piston slap.
The thing is this bike already has had some custom work done to it, before I bought it. The piston in the bike has a slight dome, with valve cut outs. The schematics show a flat top piston with no cut outs. I've been told that you can't fully trust the schematics. After this bike is dialed in on a dyno, and I've ridden it for a bit to confirm all is well. I am taking the top end off to confirm what piston it actually has, and to see if it is running a steel con-rod or maybe even an alpha bearings racing crank ( hitchcocks ). Saving money now, if the bottom end needs doing then that will be done, if not well I will get to work on the top end!
The set up on my breather, is more or less what you described some time ago on these forums, which is what I did, if I remember correctly, it may of even had photos to illustrate what you said.
My bike is currently located at the dyno, to have fine tuning to the carb, and have its mot. When it gets back, I'll take some photos.
