Hello my dudes and dudettes...I am once again in need of your expertise. So I have the ace canister for my '12 C5. I got it all mocked on there and everything seems fine. However with the canister installed it pushes on the the throttle cables a bit. Which is cause the throttle to stick open. Anything from 1/2 to WOT, it'll stick open. I've tried adjusting the cable at both the handlebars and at the throttle. But can get it straightened out. Has anyone had the same issue by chance? Thanks!
