I believe its normal for the amp meter to flick like this. At Idle on a single cylinder everything goes slow enough to physically see ignition cycles on the amp meter, combined with the firing stroke being every 2 engine rotations, you get this pusling visible on the amp meter.
Above 1000rpm it becomes a blur that the meter cant move quick enough (or humans eyes cant tell) and sorta points in a spot.
Aslong as you have it reading + at just above idle all is well.
