If that's the problem and your really losing fluid like you say you are the area should be wet.
Anyway, the source of the leak could be the brake bleed valve is loose.
It's the small hex fitting with the small rubber cap on it.
Under the cap should be dry as a bone.
If it is wet, or the area where the bleed valve threads into the caliper is wet, tighten the valve up.
It could be the banjo fitting where the hose connects to the caliper is defective or loose. Both the upper and lower surfaces where it meets the underside of the bolt or the caliper should be bone dry.
It could be just a bit of chain lube or oil that splashed on the caliper.
Oil or grease feels slippery on your fingers. Brake fluid does not.
It could be the caliper piston seal(s) leaking.
Although I think there are repair kits which provide the rubber seals available, unless you have done this sort of repair, it's best left to a mechanic who knows what they are doing.
Your CGT should be covered by a warranty that will cover any repair to the brakes so I really recommend that you take the motorcycle to your dealer and let him fix it if the problem is with the piston seal(s).
While your looking around, also check out the rubber bellows on the rod that drives the master cylinder. It isn't unknown for the master cylinder piston seals to develop a leak.
Again, if it is the master cylinder seals, let your dealer fix it.
We are talking about a life/death safety issue here so don't try to do things that are beyond your experience level.
