Home
Search
Calendar
Login
Register
Login
Register
Link 1
Link 2
Link 3
Link 4
Link 5
Royal Enfield Motorcycles
535 Continental GT
Front Axle Pinch Bolt
Login
Register
HITCHCOCKS SUPER BLACK FRIDAY EVENT
22nd NOVEMBER UNTIL MIDNIGHT 26th NOVEMBER UK TIME
SHOP NOW
10% OFF
EVERYTHING
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front Axle Pinch Bolt (Read 2558 times)
hpwaco
Grand Gearhead
on:
September 02, 2015, 06:11:32 pm
The hardest, most difficult, frustrating part of installing gaiters on my 14GT was removing the front axle pinch bolt!! I finally got it out using a 1/2" drive 6mm socket and 14" breaker bar! Once it was out I saw remains RED thread locker on the bolt! Then the axle could not be "tapped" out because the bottom of the fork leg had been "pinched" so tightly. I used a hammer and cold chisel to spread bottom slot enough for the axle to be tapped out. After all that, the fork tubes almost fell out when all clamps were loosened and the gaiters went on w/o incident (even though the package - from the dealer - was labeled for new triumph Bonneville).
I would suggest that if you have never had your front wheel off that you at least màke sure that you can remove the pinch bolt before you have to do it under adverse conditions.
Cheers
Logged
Good Vibes
Good Vibes
Scooter
50 years of Motorcycling and still love it
Re: Front Axle Pinch Bolt
Reply #1 on:
September 02, 2015, 10:49:18 pm
The pinch bolt at the bottom of the right hand fork on my bike is an allen keyed circular headed bolt. So having read of your difficulties, I wanted to check removal on my bike. With the correct sized allen key in the bolt and using the hole in the handle of an 8inch crescent spanner threaded over the allen key shaft for leverage, the bolt came undone by hand quite easily. I only loosened it for about one turn that was enough to see that it would come out easily and so tightened it up again.
There is probably some inconsistency in factory assembly for parts done by hand. Maybe I was lucky and you were unlucky. Hope everything else works OK for you.
Logged
Ralph from New Zealand
GT Continental 535
RE Bullet Classic 500
Honda Dream 200 twin
Matchless 500 single
Norton ES2 500 single
Yamaha YDS3 250 twin
Matchless G9 500 twin
BSA C11 250
Grand Gearhead
"But it's a dry heat here in Arizona
Reply #2 on:
September 02, 2015, 11:36:50 pm
I may be wrong but I think the Royal Enfields get shipped without the front wheel attached to the fork.
If this is true for the CGT, it was the dealer who assembled the bike that used the red locktite.
I have no idea what the thinking was for using red (permanent) locktite.
Maybe the mechanic was having a brain fart?
Logged
mevocgt
Grand Gearhead
Reply #3 on:
September 03, 2015, 01:57:54 am
Sometimes dealer setup guys are mechanic wannabees....
Logged
GSS
Grand Gearhead
Reply #4 on:
September 07, 2015, 10:36:57 am
Yes. Dealer issue indeed. The REs are boxed and shipped with the front wheel off.
GSS
Logged
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
medra42
Grand Gearhead
Reply #5 on:
September 07, 2015, 10:46:12 am
I've found some interesting things about the way my CGT was put together, the least of which has been Locktite in inconvenient places.
To be fair, I've found equally interesting, through fewer in volume, things on my T100.
Logged
Soph: 2012 Bonneville T100
Padma: 2014 Royal Enfield Continental GT
Igorina: 2013 Honda CB500X
Hypercafienated
Grand Gearhead
Ride In Paradise Cabo, Don and Ernie
Reply #6 on:
September 07, 2015, 04:45:58 pm
Quote from: MeVoCGT on September 03, 2015, 01:57:54 am
And they almost never "get the memo" on appropriate lock-tite selection, preparation and usage.
Logged
Print
Pages: [
1
Go Up
« previous
next »
535 Continental GT
Login
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
