Author Topic: Now This - Frame Crack :: SOLVED !  (Read 14663 times)
on: September 01, 2015, 01:25:35 am
This is too much.
The bike was kind of sinking on center stand. When I looked carefully what is going on, there is a big gap in the weld on the frame, where the stand is attached. Moreover the frame bar is also bend, arching up instead of being straight.
« Last Edit: September 18, 2015, 06:54:23 am by singhg5 »
Reply #1 on: September 01, 2015, 01:52:38 am
Sorry to hear that Br. Singhg.
 Have you thought about contacting RE USA ?  Since yours is one of the first UCE machines in the States and might be the highest mileage unit they may want to study it.
Reply #2 on: September 01, 2015, 01:59:39 am
 Yeeeesh Singh !! :o    How bad is that arch on the cross tube ?  Hard to see in the pic. Can you get a little torpedo level on it ?
JVS
  • I love chicken
Reply #3 on: September 01, 2015, 11:05:22 am
Damn  :o
Does this warrant a whole frame replacement?! Sorry about this! Keep us updated.
Reply #4 on: September 01, 2015, 11:27:50 am
judging from the picture it looks repairable.  However getting it done will be inconvenient and irritating.
Reply #5 on: September 01, 2015, 12:01:05 pm
Call Chumma,  and he can take it to Billy the frame builder,  and he can weld it for you.
Home of the Fireball 535 !
sumaris
Reply #6 on: September 01, 2015, 12:22:03 pm
Maybe it can be repaired but perhaps the question needs to be asked and understood, why it happened. Especially since it looks like the frame has bent.
Reply #7 on: September 01, 2015, 02:59:47 pm
Singh, I'm so sorry to hear this.  Make sure you have whoever looks at it check overall integrity too. I know you ride in all weather so make sure rust hasn't taken too big of a bite.
You may end up taking the bike apart for the repair but I'm betting it can be welded.
Guaire
Reply #8 on: September 01, 2015, 04:52:59 pm
The weld looks ok. Looks like the frame tube broke and let loose of the weld.
ACE Motors - sales & administration
Chuck D
Reply #9 on: September 01, 2015, 05:22:02 pm
Time to get that featherbed. ;)
 "Featherbed" frame by Rofomoto.
2017 Triumph T120
Reply #10 on: September 01, 2015, 05:29:28 pm
Some pictures with a Level in front of cross-bar. Since the level was a bit longer than the cross-bar of frame, it could not be placed on bar instead it was held in hand with its edges touching the frame.
The level has 3 water filled tubes. The middle one shows air bubble towards the left, indicating uneven position of stand - left leg being higher than right leg of stand. Though it may be slightly exaggerated by the fact that the left-weld is broken so left leg may be slightly pushed up due to weight of bike.
Another observation is that the middle portion of cross-bar is also protruding FORWARD. So much so that its edge has penetrated the tip of crankcase in front of it (pictures #3 & 4).
The cross bar is arching up & forward. And the left-weld is of course broken.
« Last Edit: September 01, 2015, 06:27:00 pm by singhg5 »
Reply #11 on: September 01, 2015, 07:27:37 pm
  Yeah, I see what you mean Singh.  Bent up and forward towards the Engine.  Weakened from the rust and  cracked  welds in the center,then distorted by the use of the center stand.  The way it looks in the pic's....  That whole section MAY have to be cut out and replaced. BTW,  Are there any drain holes on the bottom of that cross tube ?  Mine has a couple down there.
Reply #12 on: September 02, 2015, 12:51:37 am
Sorry to hear about this, Singh!  Ironic, too, what with your concurrent 40,000 mile thread...  :(
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #13 on: September 02, 2015, 01:38:25 am
Need a forensic frame examiner, who might ask "do mostly you: electric start - or kick start on centerstand? Did rust contribute to the failure?  Can it be re-welded in place - building up the stand feet & function correctly?"
  Hard to believe this happened with only normal stress & wear. This certainly adds weight to my criticism of using SIDECARS on Enfield UCE FRAMES, as it indicates under-engineering & inherent weakness.(IMO)
« Last Edit: September 03, 2015, 04:33:42 am by Craig McClure »
Best Wishes, Craig McClure
GSS
Reply #14 on: September 02, 2015, 02:40:34 am
This sure stinks especially for a well maintained bike like yours.  A frame shouldn't fall apart like this.
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
