Author Topic: Cannot Break This Bead!  (Read 1489 times)
medra42
on: August 29, 2015, 02:11:43 am
Trying to get the back tire off. I cannot get this bead to break. I've tried Bead Popper.. I've tried the wood block lever.. I've tried going at it with tire irons, and I cannot get this tire off...
Am I missing something?
Soph: 2012 Bonneville T100
Padma: 2014 Royal Enfield Continental GT
Igorina: 2013 Honda CB500X
Richard230
Reply #1 on: August 29, 2015, 03:06:47 pm
Before a dozen specialized tire bead breakers arrived on the market, I used a large woodworking screw clamp, like you would buy at a hardware store to release the bead on a motorcycle tire.  I would place the fixed side of the clamp against a piece of wood that was placed against the wheel rim on one side of the wheel.  The screw and flexible foot side of the clamp I would place on the tire rubber sidewall directly against the wheel rim. Then spinning the clamp screw bar would force the tire bead down into the wheel drop rim.  I would then be able to use my foot to pop the rest of the bead off around the wheel. Then turn the wheel over and do the same thing to the other tire bead.  That never failed me in the past.
Now I use a specialized motorcycle tire bead breaker that uses a long lever attached to a foot to break the bead, just because it is faster and I like gadgets. I might add that I have one of those "bead poppers" and was never able to get it to anything but bounce off of the tire.
2018 16.6 kWh Zero S, 2009 BMW F650GS, 2020 KTM Duke 390, 2002 Yamaha FZ1
gizzo
  • purple people
Reply #2 on: August 31, 2015, 02:02:00 pm
I use the tyre pliers for four wheel drive tyres on my bike tyres. Works like a charm.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Charro
Reply #3 on: August 31, 2015, 02:21:56 pm
Kickstand from your other bike, works in a pinch. The weight from the bike plus you leaning on it should do it. Old off-road trick.
Andy
2014 Royal Enfield C5
2004 Triumph Sprint RS
2004 Triumph Speed Four
2001 Triumph Bonneville
2006 Triumph Scrambler
1998 Triumph Speed Triple
1998 Triumph Daytona
2012 Ural Gear Up
"Tell me what kind of horse you want to ride. I'll tell you what kind of rider you are." (Old Mexican proverb)
Guaire
Reply #4 on: August 31, 2015, 05:14:41 pm
"Kickstand from your other bike, works in a pinch. The weight from the bike plus you leaning on it should do it. Old off-road trick."
  Find a guy with an HD to help. They're the heavyweights that can pop a bead with a side stand.
ACE Motors - sales & administration
