Author Topic: Anyone got a Trailblazer/Chief tank they don't need anymore?  (Read 3618 times)
RE_Chief
Looking for a Trailblazer or Chief tank, has anyone got one they don't need?
Regards Charles
1955 Indian Tomahawk 500 twin
1958 Indian Chief 700 twin (SMPB 9002 the 2nd ever made)
1960 Indian Chief 700 twin
1964 Interceptor Mk1 750 twin
1967 Interceptor Mk1A 750 twin
1994 Bullet Deluxe 570 long stroke single
2018 Interceptor 650
grumbern
Reply #1 on: August 27, 2015, 07:52:53 am
Hi Charles,
you do realize these tanks are different? The Trailblazer is a little less bulbous in the back, you can only see it from the side.
Andreas
P.S.: Did you try HMC?
Don
Reply #2 on: August 31, 2015, 08:58:03 pm
Charley
Are you going to use it on one of your Interceptors? My Trailblazer tank is a direct  no mod fit on several Interceptors, both Series 1 and 2. That I have run over the years.
Other than fitting up a second fuel petcock of course.
You do have to be careful routing cables since the big tank is deeper and wider.
Love the extra range the big tank gives you.
Don't know how the Chief tank will fit.
Cheers
Don
1965 Series 1 Interceptor
1970 Series 2 Interceptor
RE_Chief
Reply #3 on: September 02, 2015, 12:22:08 pm
One of my Chiefs came with a Greeves tank, I think, anyway I need a tank for the Chief to get it going, a Trailblazer tank will do if I can't find a Chief tank.
When I eventually find a Chief tank the Trailblazer tank can go on the Trailblazer that I will build eventually.
So Don do you have a Trailblazer tank you don't need any more.
Regards Charles
grumbern
Reply #4 on: September 05, 2015, 09:55:42 am
I do have a Meteor tank, that looks the same as the Chief, but doesn't have the chrome panels.
Andreas
RE_Chief
Reply #5 on: September 09, 2015, 06:58:15 am
Do you have any photos please.
Regards Charles
grumbern
Reply #6 on: September 09, 2015, 09:29:46 am
Here you go!
RE_Chief
Reply #7 on: September 09, 2015, 11:15:40 pm
Many thanks Andreas, but I have an old Bullet tank which looks pretty much the same so I can use that for the moment.
By the way what's the frame you have there?
Regards Charles
grumbern
Reply #8 on: September 10, 2015, 08:17:11 am
59 Chief ;)
RE_Chief
Reply #9 on: September 10, 2015, 12:19:34 pm
Is that the one for your rebuild?
Regards Charles
grumbern
Reply #10 on: September 10, 2015, 03:46:26 pm
Yes, it is and the tank was the one I got with it. Compared it to the one I got from HMC and its quite the same, with the differences as said.
Andreas
