Typically, if you were riding at 60mph for a while, then you assembled things right, and so the problem is likely one of tuning or possibly an air leak. Check the rubber hose between the carb and manifold, and check the gasket between manifold and head for air leaks.
I can't remember what carb you are running, but it might need better tuning.
