Might as well carry this on...
So I took a ride, and took some photos…
The ride is about what I was led to expect - more power than the Enfield, good torque throughout the range. The ride seemed to be about the same as the RE, too - pretty stiff and tough over the bumps. Handling is not quite as responsive as the RE, but still within the ballpark. My RE is smoother at similar lower RPMS, but by the time I touch 3500, it's vibrating much worse than this Triumph does at any RPM. Clutch feels good; gears shift very hard. Front brake is so-so; adding the rear really boosts the stopping power. It's not set up well for me at all - I'd need to adjust the shift lever; it doesn't look like the brake lever is adjustable - unless I put the lever in a vise! Aside from the advice given here, another friend (who owns a 1968 version of the same model, that he's owned since… 1968!) suggested that I pay attention to the wiring harness - I suppose because his gave him some headaches. On this bike, the term "harness" is probably a bit generous, but everything seems to work.
Again, new or recent:
Rims and spokes
Avon Roadmaster tires
chain and rear sprocket
unknown engine rebuild work (I know...)
front forks
Mikuni carb and manifold
Boyer ignition
exhaust header pipes
Some pics...
The frame tubes between the exhaust and the front wheel are slightly dented:
Engine, right side. New exhaust headers:
"New" Mikuni carb and intake manifold. The yellow film is actually fuel dripping from the leaky tap. I don't know why it's that color. Owner says, "Vinalhaven gasoline?"
More fuel drips on the right engine cover:
The offending leaky tap, with a drop showing:
Tank has a "repaired" paint ding, center, just above middle. The inside of the tank is pristine - clean metal, no rust:
Right side:
Front wheel and hub. New rims and spokes front and back. Fork tubes look new, as do the seals. Front brake works… hmmmm… well, mostly:
Engine, right side:
Rear wheel; back brake really adds noticeable stopping power. Cocktail shakers with no baffles are pretty loud. Our engineer says he sees smoke, especially from the left side - rings? Previous owner (who sold my guy the bike) says compression was fine last year (100 miles ago)...
Wiring seems a bit dodgy in places:
Bike, left side:
Dash. Gauges work, but rubber is a bit crackly. Steering seems tight. 18,050 miles:
Under the seat: the seat covering has worn the paint away from near the oil fill:
Ignition component?
Battery and wiring seem dodgy as well. Since it's kick-start only, I'd change the battery to something cleaner, if not a bit smaller:
A bit gunky underneath, but again, no puddles on the garage floor. That's a new chain and rear sprocket, too, btw:
