Laurence:
I would replace all of the PAV hoses and check the area where the carb bolts to the engine inlet.
A small air leak in any of these can cause the poor idling and rough running your seeing.
I know you drained the float chamber but in all likelihood, the small fuel jets in the carburetor are crudded up with varnish.
I would also buy a bottle of Techron carb/injector cleaner and pour an overdose of it into the fuel tank (like 1/2 of the bottle).
I would then drain the carburetor float chamber letting out enough fuel to be sure that the Techron treated fuel would be filling the carburetor.
Letting it sit overnight, I'd give starting it another try and I'd keep it running for at least 5 minutes (or more). A good ride will keep the Techron moving thru the jets which will help to clean them out.
A more major approach would be to totally disassemble the carb and blow a dedicated carburetor cleaner thru all of the jets and passages but if you do this, you will probably have to readjust all of the settings.
