Author Topic: Help fix my fathers bullet 500?  (Read 4770 times)
longstrokeclassic
Reply #15 on: August 21, 2015, 09:08:38 am
well i have a weird problem i can only find the 8 number vin on both the engine which is 5B53947A and the frame
That is the only number you need :)
On the 8 digit number you have the 5 is for the year, the B for bullet and the second 5  for 500cc.
 3947 is the unique frame identifier for the bike and finally the A is the month of manufacture. Where things get interesting is that the 5 denoting the year used to repeat every 10 years, hence the introduction of a recognisable VIN system which put an end to this confusion.
Looking at the alternator wiring with its 12/94 production stamp and that one of the date of manufactures could be January 1995 (one month later) that's where I'd put my money. There might also be a date stamp on the rear of the points plate for further confirmation.
« Last Edit: August 21, 2015, 09:36:16 am by portisheadric »
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
flyboy
  • Keepin the shiney side up
Reply #16 on: August 21, 2015, 03:24:47 pm
With all due respect to David Blasco for the wealth of RE information he provides us....the VIN decoding he provided is wrong. And I believe the same format is used internationally.
He begins his 'decoding' with the letter "T", which is actually a 1996 year model, not 1995 as represented. ('95 is used letter "S"). Additionally, there is no letter "U" used in the 17-digit VIN format. (Skipped letters are "I"; "O"; "Q"; "U"; "Z")
Therefore, he remains correct from "V" (1997) thru "6" (2006). So, "7" is a 2007, "8" is 2008, "9" is 2009. The format begins again with "A" beginning 2010.
