My GT has a subtle "zit-zit-zit" sound which keeps pace with the front wheel rpms when in motion, that becomes a steady "zizzzzzzzzzz" sound when the front brake is on. I assumed it comes from the pads skimming the disc (which they do all the time) as the vent holes pass through the pads, and the disc not running exactly true within a few thousanths. No issues or unusual wear evident after a few thousand miles, and less obvious with the stage 2 muffler on the bike, and/or after I've smoked a really good Arturo Fuentes cigar which tunes my tinnitus up enough to drown it out.
