Hi Everyone.
I'm new the the forum and new to riding RE's. To start with, I'd like to thank all of you for posting your problems, solutions and general comments on Royal Enfields because it sure has helped me a lot to understand them better and it motivated me towards my purchase of a 2015 B5 this May. Since then I've put 2500 miles on the bike - 2500 happy miles!
Sure, there have been a few minor issues but nothing that couldn't be easily taken care of, mostly adjustments that were expected thanks to you all. The negative battery terminal was vibrating against the frame of the bike so put a piece of rubber behind the battery to bring it out a bit - problem solved. The brake rod was vibrating against the muffler bracket - easy fix. Stuff like that.
The one thing that had me puzzled was that I could never see oil in the sight glass even following the owners manual method for checking it. Since the bike is new, all the oil changes have been done by the dealer (love the dealer) so just had to trust that the oil level was correct. Today while laying on the ground with a flash light and once again looking for any signs of oil in the engine, I decided to add just a little oil at a time to the crankcase to see if I could tell a difference. Bingo! All of a sudden after adding about an ounce of oil it showed up in the sight glass plain as day! I'll speak the the dealer next time I'm there but I'm thinking that they just measure in the correct amount of oil and it's just short of showing up in the glass. Took the bike out for a 30 mile ride and rechecked when I got home and was happy to see the oil level between the marks on the case.
Just another happy Enfield owner.
