I posted a couple of weeks ago that the dealer over-filled the oil and I had to drain a bunch out. And the trans fluid was so over-filled that it was bubbling out. I drained those two down to normal levels right away. But I just got the bike back together after fixing something else they did to cause oil splattering all over the back end of the bike. The two oil drainage hoses coming out of the engine had for some reason been re-routed so they ended on top of the rear fender, under the regulator/rectifier below the seat. And one hose had been split and they thought a piece of electrical tape would take care of that. So oil was getting all over the top of the rear fender under the seat, and from there it was getting all over the chain guard, rear wheel, pipe, and pretty much everything at the back end. It was everywhere.
After washing the oil off everything twice and throwing away the mess of hoses they made, I got some new hoses and re-routed them so they run down and dump any drainage on the ground alongside the rear tire, instead of all over it or in front of it. One problem remains: the smaller of the two hoses (the forward-most one where they come out of the engine, just in front of the ignition module) is still draining oil a lot. The oil is dripping out while it's idling. The rear hose isn't draining anything at all after I drained the excess oil out. The oil level is just slightly to 1/4" below the top mark on the dipstick (depending if the oil is warm or cold). I figured that was low enough but I'm still getting excess oil drainage from that hose. The level is about the same as I always kept it before I took it to the dealer and it never had this problem before, so I don't know what's different now.
So do I still have the oil level too high, or am I missing something else entirely?
