Author Topic: Discovered A Noise Today  (Read 5082 times)
on: July 25, 2015, 10:18:27 pm
     I discovered a noise today just by accident that concerns me a little.
      2008 AVL Classic. 1,091 miles since bought brand new in December 2010 (Left-over, zero miles, perfect). No off-road, no bad roads, no potholes worth mentioning. i weight 140 pounds.
       Today on the center stand, sitting on it, for some reason I pulled up on the handlebars sharply. Really jerked them up hard, let it down and did it again.
        I got a very clear metal-to-metal sounding clank sound. This is the first time I have ever heard this sound. I've heard no sounds from the front end at all - ever and the front end is tight on the road, solid as a rock, never a wobble, never a wiggle, never a sound, tracks like a slot car.
         Oh, shit. I, personally, have a very bad neck, but now do I have a bad neck on the bike. It's so good on the road and I've never heard this noise on the road, that I can't believe it's something drastic. I Reeely reeely don't wanta have to take the neck apart. I work alone, I'm F-ed up joint painwise and have only done harleys.
        Maybe I'll just forget I ever heard it  >:( :o  :-[  :-X
« Last Edit: July 25, 2015, 10:21:23 pm by tooseevee »
Reply #1 on: July 25, 2015, 10:31:35 pm
They are just ball bearings in there.
Sometimes it can be just as easy as a little tightening of that big nut on your casquette. Tight enough, no binding.
Home of the Fireball 535 !
Reply #2 on: July 25, 2015, 11:22:20 pm
            Just cop a feel on the big nut for a start? As simple as that?
             And you would not hear or feel that on the road at all, I guess?  It would have to be just the right type of bumpy road to hear it, I suppose.
Reply #3 on: July 25, 2015, 11:24:34 pm
The UCE manual says to adjust the tension on the front steering head bearings, first, with the motorcycle on the center stand, jack up the front of the frame to unload the weight on the front wheel.
Then, loosen the two lower bolts that clamp the fork tubes at the bottom of the steering yoke.
Then, tighten the large steering head nut (the big chrome one) to 70-80 Nm (52-59 lb/ft).
Loosen the big steering head nut and re-tighten to 2-4 Nm (1.5-3.0 lb/ft, 18-36 Lb/inch).
Re-tighten the fork tube clamp bolts/nuts to 33Nm (24 lb/ft).
That should seat the balls and reset the pre-load on the steering head. :)
Reply #4 on: July 26, 2015, 12:08:57 am
             So we're very sure that this can be the only source of that clunk - right?
              Because I just went down and the big nut is VERY nice and tight already (30mm 3/4" drive socket with a breaker bar). That means it's NOT right relative to the two fork tube clamp bolts so I'll delve into that tomorrow morning.
              The front wheel is very free on the center stand and I don't get the clunk noise by jerking up OR forward on the front wheel. Only by jerking up on the handlebars.
               Thanks a lot to both you and Ace. Seems a simple fix. I have no torque ability for that large nut. I think I can feel it OK.
                PS: Always keep your balls seated  ;)
Reply #5 on: July 26, 2015, 12:35:17 am
    OK - I went back down there and it's all clear now. Those two lower flange bolts are the ones that hold the RE logo under the headlight. Duh  :-[
     I can't go down again - too many times today.
      Thanks again, guys.
Reply #6 on: July 27, 2015, 08:59:47 pm
             No one has mentioned the 8mm steering stem lock bolt that the AVL has (I don't know about the UCE). Looking forward it's right under the handlebar bracket. That stem ain't gonna move up or down without that bolt being loosened.
             I've got everything together and will attack it later. It's 90 degrees here right now and like a steam bath.
             PS: Why do you need to loosen the fork clamps? (The two bolts that hold the RE logo under the headlight).  You're not moving the forks when tightening the stem. Are you?
Reply #7 on: July 27, 2015, 09:15:26 pm
If the bike has the casquette, the forks can't move up, because they are threaded into the casquette, and so the casquette cannot move down with the big nut. The upper bearing race is pressed into the casquette. So, if it needs much movement to tighten the bearing, you would have to loosen the lower fork clamps to allow the bottom race to move upward.
Most of the time, a little tightening is all that's necessary, and i don't usually bother with the fork clamp bolts. But if it needs any significant tightening, it would be best to loosen the lower fork clamp bolts.
Reply #8 on: July 28, 2015, 02:00:36 am
The way the Service Manual talks, that big Allen bolt under the handlebar bracket does not have to be loosened to adjust the preload on the steering head ball bearings.
If you were removing the whole steering head you would take out that big bolt to remove the casquette.
Like Ace says, the upper bearing is pressed into the casquette.
Think of it this way:
You are really raising the lower steering yoke and its bearing upward towards the casquette when you tighten that big nut.
Because the lower yoke needs to move upward towards the casquette, the bolts that are clamping the fork tubes to the lower yoke need to be loosened.  If they are not, it can't move upward as that big nut is tightened.
Reply #9 on: July 28, 2015, 06:29:01 pm
     Some time during a long night I searched back and found where I got this Allen Head Lock Bolt idea. It was from singhg5 on Tech Tips in October 2014. He wasn't sure at that time, but he thought it was a lock bolt.
      Then I dug out my Snidal and Pete also says it's a lock bolt in his 2006 Manual (Page 118).
       It's NOT.
        I went down this morning and adjusted it by the book from all the info I've gleaned from here and other places.
        Bike on center stand. Weight off front wheel, wheel just barely kissing the floor.
        Back off lower flange pinch bolt nuts. Loosen pinch bolts.
        Just break Big Nut loose then tighten to 55 pounds.
        Break loose and retorque to 3 pounds.
        Tighten lower flange pinch bolts.
        I did this twice and still had "The Clunk" when I jerk up on the bars with the front brake on.
         So I did it all AGAIN and left the Big Nut at 55 pounds.
          I still have smooth turning side to side with no bad sounds or resistance AND I still have "The Clunk".
          I'm ready to just forget it because I cannot get ANY hint of noise, no matter what I do, with the bike on the ground.
          Should I try to get to 80 pounds or something else ridiculous.
          Am I the only one out here with an AVL with a clunk? Am I the only one who's ever even honked on their bars to "see" if there's a clunk? Am I the only one who's ever done this? I feel like Mr. Jones (...something is happening here, but....).
           It's like working in a steam bath here today.
Lane
Reply #10 on: July 28, 2015, 07:42:00 pm
       It's NOT.
Mine has a clunk when i push / pull on the bars but i always thought it was the forks coming back to full stop after the slight compression that occurred. Much harder to make the noise when not on the center stand cause all weight off the front forks except when tilted to the front, of course, but then only a little. Everything else about the steering seems tight so i never worried about it.
Could it be something like that?  1000+ miles seems like everything would be practically brand new.
Good Luck and let us know!
Reply #11 on: July 28, 2015, 07:59:40 pm
           Yes, the bike is literally brand new. I got it (an '08) as a brand new, never ridden, never sold, never registered left-over in December 2010 from the lawyers of an out-of-business dealer. And they've been very easy miles. Not babied, but not beat either.
            I had SWMBO listen with a tube in her ear. The sound is definitely inside the steering head. It is not coming from anywhere along the length of either fork tube.
            I'm gonna ride it later when the sun gets lower (it's unbearable here right now). On the ground the feel is perfect at 55 pounds torque on the big nut. I just don't get it. Seems like I should be feeling some drag. And the preset is supposed to be tight at that torque ???  but I still have a clunk.
Reply #12 on: July 28, 2015, 10:12:36 pm
I suggest, since the clunk didn't go away, you should return the final nut torque to about 3 lbs/ft.
Your present 55 lb/ft torque is pre-loading the ball bearings to around 3,700 pounds of axial force.  The raceways aren't designed to operate at that high load.
Riding the motorcycle with this high of pre-load could cause the balls to brinnel (indent) the raceways which will lead to poor steering over time.
Reply #13 on: July 29, 2015, 12:12:54 am
            (I never did ride; it was just too damn uncomfortable - steamy hot - then it poured rain).
            If I have such a huge pre-load (55 pounds) on the balls and races, where is the clunk being produced? If the balls are squeezed that tight, what's producing the clunk?
             Why don't I feel the slightest drag or tiny bit of resistance? Should I try 80 pounds?
              Do you think the lower pinch flanges might not be letting go even though the bolts are unscrewed?  not allowing the slack to be taken up in the bearings even at 55 pounds leaving me still with the clunk no matter how many times I do the 55 pounds?
               And how can the balls be squeezed so hard (as you say they are) and there still be a clunk? Isn't the clunk produced by the balls and races slamming together? And there shouldn't be any slack between the balls and races at 55 pounds - correct?
                I'm confused and about to just go put the big nut back to 3 or 4 pounds and forget the whole thing and just ride the bike.
Reply #14 on: July 29, 2015, 04:36:07 am
At 55ftpd I'm surprised it still turns.  What exactly are you doing typ produce the click while it's on the center stand?  To me it almost sounds the forks are making the noise, not the steering stem.
